Replacement trunk steel pan for rusted out one?
Old Jun 30, 2019 | 01:53 PM
testdepth's Avatar
5 Year Member
Default Replacement trunk steel pan for rusted out one?
Does anyone make an aftermarket bolt in replacement steel pan for the trunk? All these rusted out trunk pans under the spare must mean someone makes a bolt in replacement.
Old Jul 1, 2019 | 11:27 AM
tony_2018's Avatar
Fish Twig
Default Re: Replacement trunk steel pan for rusted out one?
Hm, my sisters db7 hasn't rusted. Everything is welded together btw.
Old Jul 2, 2019 | 07:38 AM
testdepth's Avatar
5 Year Member
I understand the original pan is welded in. I was asking if anyone makes an aftermarket replacement to install vice smearing bondo or fiberglas on it for a temp fix.
Old Jul 2, 2019 | 08:03 AM
jdmark1's Avatar
You can't install a new spare tire well by adhering it to the chassis with Bondo...if you aren't able to weld in a new one, then take it to someone who can. As far as purchasing one, Honda may still sell them so check on oemacuraparts.com. if not, then source one from a salvage yard that's in a state like California, New Mexico, etc
Old Jul 2, 2019 | 02:27 PM
tony_2018's Avatar
Fish Twig
OP must be thinking of some metal bonding adhesive from 3m. Even that method still requires tack welding and seam sealing.
Old Jul 7, 2019 | 05:16 AM
testdepth's Avatar
5 Year Member
