Honda Civic 97 CX Hatchback - Fuel Sending Unit
Old Jun 25, 2019 | 08:51 AM
billyjobs's Avatar
Default Honda Civic 97 CX Hatchback - Fuel Sending Unit
Are there any other fuel sending units that can fit in a 97 CX Hatchback?
I'm having very difficulty finding the fuel sending unit for this model and they all seem to be discontinued. I'm open to buying a used one or from another model that can fit. Like can the DX model fit?
Thank you.
Old Jun 25, 2019 | 02:13 PM
muellersfan's Avatar
Default Re: Honda Civic 97 CX Hatchback - Fuel Sending Unit
Did you check at AutoZone or Rockauto?
Old Jun 25, 2019 | 06:01 PM
billyjobs's Avatar
Yes it seems like they only have the fuel pump but not the sending unit.
Old Jun 25, 2019 | 06:24 PM
Would you consider a used one? eBay returns are easy if product does not work.
The first link also shows compatibility with various 97 Civic trims.
The second link says it's compatible with 96-98 Civics.
https://www.ebay.com/itm/96-97-98-HO...IAAOSwCyVck86q
https://www.ebay.com/itm/96-97-98-Civic-Gasoline-Fuel-Meter-Sending-Unit-Assy-Used-OEM/162670417682?epid=1022150734&hash=item25dfe99712:g hoAAOSwgKpZtwdH
Old Jun 25, 2019 | 09:22 PM
billyjobs's Avatar
Yes I saw those but they look different from the CX hatchback, not sure it they will work.
Old Jun 25, 2019 | 09:23 PM
Post pics of your sending unit.
Old Jun 25, 2019 | 11:33 PM
billyjobs's Avatar
I put it back into the car else there would be a big hole and gas splashing out everywhere
But here's the part:
https://www.xportautoparts.com/oem-p...el-37800s04a01
Old Jun 26, 2019 | 03:58 AM
That crude diagram should not be used to determine whether the eBay Civic sending units are a match for your car.
Old Jun 26, 2019 | 04:51 AM
billyjobs's Avatar
Ill pull it out again later today and get a photo
