Rough Idle, looking for location of idle adjust screw
Old Nov 14, 2002 | 01:54 PM
oi-punx's Avatar
Default Rough Idle, looking for location of idle adjust screw
I am experiencing a fluctuating idle with the '89 Civic LX 4 dr that I just bought. It normally idles around 500 rpm, but will occasionally rise to the normal 750 and might drop to around 400. I pulled the cover off of the throttle body yesterday and sprayed some cleaning solution down there. The idle seems more consistent now, but is still in the 500-600 RPM range. I think i'll need to either pull the assembly completely off and clean it more completely and/or adjust the idle screw. Does anyone know where this screw is on this model? I looked around the TB and the cable linkages and can't seem to locate it. Do I need to pull the throttle body completely off for access? I think this is my problem, unless it is normal for these cars (This is my first Honda). The car just had a full tune-up except for the ignition rotor (which may or may not be new). My money is on the idle adjust screw.
Thanks
[Modified by oi-punx, 10:56 PM 11/14/2002]
Old Nov 14, 2002 | 02:01 PM
jdm4life's Avatar
Default Re: Rough Idle, looking for location of idle adjust screw (oi-punx)
It should be ontop of the throttle body
Crxdriver1989
Dec 19, 2017 01:28 AM
CHANCELLOR12
Feb 6, 2016 03:46 AM
itzyaboyzeem03
Sep 30, 2009 04:11 PM
924doorEG
Nov 19, 2007 08:15 AM
