'16 Odyssey RPM Surge at Lower Speed
2016 Honda Odyssey SE with 60K
I have an issue where around 1500'ish RPM and light throttle(35-45 mph) the RPM's will surge up then back down a couple of hundred.
I have no lights or error codes and the van idles fine and runs fine at higher highway speeds.
Anyone encounter and solve this issue?
The van idles great, runs fine at cruising speed(60-80) on the Autobahn. There is a little hesitation when you begin accelerating from the RPM range where the surging occurs.
I've yet to find a solution. There are no lights or codes indicating a problem.
I'm looking at replacing the EGR valve and see if that helps.
I'm surprised that there are no post regarding this issue and a solution to this issue.
angelovargas
Jul 15, 2004 01:35 PM
