Turbo H22a Sleeved Block Crack
Old Jun 22, 2019 | 11:36 PM
[LUDE]'s Avatar
Default Turbo H22a Sleeved Block Crack
Hi all
I have just removed my head to find a crack in my block next to where I've had darton sleeves installed. the car has been running fine for 2 years beside blowing a bit of smoke when first started (The reason I took head off) I assumed valve guides. Ive been running 28psi and made 525hp on hub dyno. Any help would be appreciated.
Old Jun 24, 2019 | 11:34 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Turbo H22a Sleeved Block Crack
If you are not mixing coolant and oil, and there are no signs of pressurizing the block under boost... I wouldn't worry about it. You might put some silicone or epoxy in the damaged area to be on the safe side and limit fluid movement into the sleeve/socket area... but it is likely not a big deal. If you do try and seal off the area, make sure the deck is totally flat before you re install the head.
Old Jun 24, 2019 | 01:29 PM
Ryanthegreat1's Avatar
Superficial, run it. Nothing more than a thin/weak spot in the casting that was left over from machining to put the sleeves in.
