Which AN 6/8/10 fuel pump match for D16y8 ZC
Also about fuel feed injector can install any kind injector for some boost, before but there turbo system?
Example 500cc more or less
Have today air filter for air intake..
If read ZC under engine what is mean with D16Y8
Did it vtec kind?
(going uprage radiator to fully aluminium, pipes silicone, but before it change thorttle with new tps and plug with dmg, also manifold buying from aliexpress copy the sunk Pro series bit without logo and name, also cable gas/fuel going change to new..is problems stuck in some rpm or make backfire when began driving with first speed after the car stand number hours the exhaust like make small explosive and stuck..but after short way is gone, of course guess is because the thorttle not opened good is old if even clean it with put in oil for 24hours.)
Also big thing how found and know parts size for inside engine, because need make inside engine parts like spin and what come with this more strong kind, enough to turbo system..
Sorry my bad English, some time even from my language to translate it with Google to English make it salad..
Hope you understand, and Thnx if read at this point.
Did it vtec kind?
