Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2005 Honda Odyssey front suspension noise
Old Jun 21, 2019 | 04:56 PM
phen10's Avatar
Default 2005 Honda Odyssey front suspension noise
Hi,
I just go done replacing my front wheel bearings and CV axle on both sides of my vehicle. I made sure all bolts are torque to spec but I am hearing a noise. It only happens when I press on the accelerator from a stopped position. Its like a single knock or creaking noise and doesn't happen at faster speeds. I also replaced the lower ball joint and tie rod end on the driver side. The noise started after I got a alignment done.
Just wondering if anyone has any ideas what this might be??
Old Jun 24, 2019 | 12:54 PM
canister's Avatar
5 Year Member
Default Re: 2005 Honda Odyssey front suspension noise
What axle have you used - Honda or aftermarket?
Also check in this order: sway bar bushings, sway bar links, ball joints.
Old Jun 24, 2019 | 01:50 PM
phen10's Avatar
I am using an aftermarket axle from TRQ. Thanks for the suggestion, I will take a look at the sway bar and links. When I was removing the lower arm, I had to loosen the sway bar to get one of the bolts out on the lower arm..
Old Jun 25, 2019 | 05:59 AM
canister's Avatar
5 Year Member
Could be struts and strut mounts too.
Old Jun 25, 2019 | 07:34 PM
phen10's Avatar
Thanks for you suggestions. I narrowed it down to the lower arm bolts. The needed to be tightened more. Noise is gone now.
