2005 Honda Odyssey front suspension noise
Hi,
I just go done replacing my front wheel bearings and CV axle on both sides of my vehicle. I made sure all bolts are torque to spec but I am hearing a noise. It only happens when I press on the accelerator from a stopped position. Its like a single knock or creaking noise and doesn't happen at faster speeds. I also replaced the lower ball joint and tie rod end on the driver side. The noise started after I got a alignment done.
Just wondering if anyone has any ideas what this might be??
Re: 2005 Honda Odyssey front suspension noise
I am using an aftermarket axle from TRQ. Thanks for the suggestion, I will take a look at the sway bar and links. When I was removing the lower arm, I had to loosen the sway bar to get one of the bolts out on the lower arm..
