To Do or Not to Do
Old Jun 16, 2019 | 08:11 AM
Poleke's Avatar
Icon5 To Do or Not to Do
I am really new to Hondas and I get all kinds of advice that helps and confuses.
I am not in the process of changing the head gasket on a 1995 Del Sol and I am not sure what I need to do.
I have been told by mechanics to use and not use Permatex Copper Spray On Gasket on the head gasket itself i.e. two coats on each side.
I also talked with the machinist who resurfaced the head and he stated that it should be used.
I also talked with a couple of Acura/Honda experts that said not to use.
My question is: DO I USE IT OR NOT?? AND
if yes, after applying the two coats on the gasket, how long do I wait to before installing?
In the same mode, after placing the gasket on the block and setting the head, do I wait to torque or is it mandated that it torqued in a specific time period.
Any advice would be appreciated and any additional instructions would also be appreciated.
Old Jun 16, 2019 | 11:25 AM
mk378's Avatar
Default Re: To Do or Not to Do
Don't use it. Modern gaskets are coated with a sealing material and additional sealer will interfere with it. A Fel-Pro stock type gasket is marked "USE NO SEALANT" right on it.
Make sure the head and block surfaces are perfectly clean and dry.
Old Jun 17, 2019 | 02:23 AM
NVturbo's Avatar
O.G. triple O.G.
get a Genuine Honda head gasket and you should be good. No copper spray needed.
Old Jun 17, 2019 | 05:17 AM
tony_2018's Avatar
Fish Twig
check for warpage on the block and the head.
Old Jun 19, 2019 | 08:54 AM
DumpdEJ6's Avatar
I like the tuna here
You're going to get conflicting opinions here as well, OP. I have used the copper spray on every head gasket job I do, and have had zero issues. Would they have had issues if I hadn't used it? No way to tell. All I can say is that so far it hasn't caused an issue, and therefore I'll mostly likely continue to use it.
Old Jun 20, 2019 | 01:49 AM
bks84's Avatar
Loved
I dont ever use it.
