2000 Honda Accord fuel problems
Old Jun 15, 2019 | 06:18 PM
user 1959825's Avatar
Default 2000 Honda Accord fuel problems
I have a 2000 Honda Accord it was given to me free of charge it was running great when i first got it i let it sit to long and had to charge the battery after i took the battery out and chearged it up i put it back in then the car would turn over but not start it is getting great spark but no fuel to the fuel rail for the injectors i have installed a new fuel pump but still no fuel to the injectors can anybody help.
Old Jun 15, 2019 | 11:01 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 2000 Honda Accord fuel problems
Are all the warning lamps properly illuminating and then turning off after prove out and start?
What is the green immobilizer 'key light' doing when you turn the ignition to II(ON)?
If it is rapidly blinking or not illuminating then there is most likely a problem with the immobilizer system.
Old Jun 16, 2019 | 04:40 AM
If it is the immobilizer system then what can i do about that how can i reset it could me taking the battery completely out to charge it have done something to set this in motion.
Old Jun 17, 2019 | 09:18 AM
if you are talking BOUT THE gREEN KEY LIGHT IT FLASHES OFF AND ON NON STOP I KNEW NOTHING ABOUT THIS IMMOBILIZER SYSTEM AND THAT MUST BE THE PROBLEM WITH THIS CAR IS THERE ANYWAY TO RESET THIS OR Have it fixed or i just had a realy big paper weight,
