2004 Accord V6 m/t p1077 code
Can someone please give me some insight how to get rid of this code.
“ Intake Manifold Runner Control System Malfunction Low RPM “
I have already replaced the Actuator Assy., Bypass Valve part # 17150-RCA-A01
any insight or help would be MUCH appreciated !!!
Actually the intake was removed and cleaned.
This code didn’t come on until I had the timing belt replaced.
Does the actuator have to be “ timed “ when you replace it ?
I figured you would just unplug & unbolt and install the new one.
did you figure it out I’m having the same issue replaced motor and cleaned the valve
I’m sure if we took it to a dealer or someone how has the Honda software they would know how to remedy the problem.
Atomic646
Dec 16, 2012 08:05 PM
