Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Wipers Sweep Too Far
Old 12-17-2010, 04:32 PM
sparklenana's Avatar
Icon6 2004 Wipers Sweep Too Far
Just changed the battery and since then the wiper arms sweep way too far. When it goes to the right, the blades slam down to non-use position. Sound is way annoying and driving me nuts. Is this just an adjustment or a part that needs to be replaced. I don't want to go to the dealer, they love guessing and piling on the charges.
Old 12-18-2010, 11:33 AM
ekb16's Avatar
Default Re: 2004 Wipers Sweep Too Far
first check to see if the arms in tighten down. If there is still excessive movement in the arms when it is off then u need to replace the wiper arm links
Old 12-18-2010, 12:36 PM
hondaZvic's Avatar
you could try re-adjusting them..
Old 12-18-2010, 08:55 PM
Chiovnidca's Avatar
Are the wiper arms out of adjustment? Or are the link rod bushings worn out?
Old 12-25-2010, 08:11 AM
soon2bdropped's Avatar
i have an 05 accord with 120k on it.. i can apply the wipers on the dry winshield it will sweep back and forth fine.. but if i spray washer fluid on the glass or it rains it gets very sloppy and hit the apillar and bottom of the cowl really hard. the nuts are tight. so im thinking its the bushing in the transmission linkage.. can the bushing be replaced seperately or do i need the whole entire linkage at honda?
Old 12-26-2010, 04:18 AM
lazlong's Avatar
Originally Posted by jessb
How do you adjust them?
You take the nut off the top of the arm where it connects to the linkage and move it a tooth or 2 either way.
Old 12-26-2010, 11:15 AM
bump anyone know?
Old 12-26-2010, 06:13 PM
lazlong's Avatar
...can the bushing be replaced seperately or do i need the whole entire linkage at honda?
Get out your wallet: http://www.hondapartscheap.com/south...t=0&quantity=0
The page in this link is for the 4 door DX as an example. Use the link to find your specific model.
Old 12-26-2010, 08:50 PM
cant really see by the diagram but it looks like i can get part number 7 with the pivots?
Old 12-27-2010, 06:35 AM
lazlong's Avatar
No bushings listed. You have to buy the assembly.
Old 03-14-2011, 05:17 PM
Jspectyper's Avatar
What did you end up doing? I have the same problem on my 03 Accord
Old 03-14-2011, 06:00 PM
never took it apart to figure out what is bad. so you let me know what you find. probably worn transmission linkage.
Old 03-17-2011, 07:11 PM
slammed_s2k's Avatar
you need to replace both "a" and b" wiper arm linkages..they are broken just wear and tear
Old 03-17-2011, 07:12 PM
the bushings on the linkages are broken that is
Old 03-19-2011, 06:55 PM
Jspectyper's Avatar
fixed it today with the 2 new linkage arms that have the new plastic cap bushings in them, about $25
Old 01-02-2016, 03:08 PM
othello's Avatar
Although the last post in this thread is from 2011, it pointed me in the right direction to correct the same problem on my 2004 Accord earlier this week.
As Jspectyper posted, about $25 for the linkage arms and an hour or so of work in the driveway.
Having the wipers operate correctly, and almost soundlessly, is a great improvement!
Old 03-06-2022, 06:08 PM
Newtechnick's Avatar
All of these Solutions are well and good but they don't address the OPs original comment about how this occurred after the battery was disconnected. I too have experienced the same thing on my '04 Accord. Washer wipers were working just fine with no noise before the battery was changed and now they're slap crazy and driving me mad. A mechanical failure doesn't account for an electrical component being the initial instigator (seemingly).
Any thoughts?
Railroader
10-22-2017 04:10 PM
spectastic
Honda Civic (2001 - 2005)
01-28-2013 08:08 AM
chatham
05-20-2006 10:18 PM
Thrillhouse
05-20-2005 11:50 AM
G3NR8
04-03-2004 04:57 PM
Quick Reply: 2004 Wipers Sweep Too Far
