I purchased a used Kaaz/Spoon diff for my B18B1 and am currently reassembling it after inspection. I have some questions.
1.) What size are the thrust washers supposed to be?
2.) How much clearance is allowed between the thrust washer and the cone spring?
3.) Where do I purchase said thrust washers?
4.) Can I run my diff with its current thrust washers?
I have a picture of the two thrust washers and their cone springs below.
*Thrust washer A, which I would GUESS is original to the Kaaz, has an OD and ID that matches up pretty well with the diff *Thrust washer B has an OD that is too small for the diff case, and an ID that is too large for the axle diameter *Thickness is as follows: *B = 1 mm *A = 0.7 mm
