Key stuck in ignition
Old Jun 8, 2019 | 04:17 PM
Kelly Obrien's Avatar
Default Key stuck in ignition
Car was stolen then recovered. Now there is a key stuck in ignition. I don’t know if I get the key out if it will work with regular key but if I leave it in there can be stolen easily again.
Old Jun 8, 2019 | 04:51 PM
tamboo's Avatar
10 Year Member
Default Re: Key stuck in ignition
the key lock cylinder (the part the key is stuck in) is easily removed,
https://www.youtube.com/results?sear...switch+removal
without the lock cylinder you can just use a screwdriver to start it.
at least you wont have a key in there to tempt someone
but without additional security replacing the lock cylinder isnt going to deter anyone.
a cheap security measure is to get a 15 amp fuse and grind the tabs off then
swap it with the under hood ecu fuse to disable it.
might be enough to make the scum move on to an easier target
Old Jun 10, 2019 | 05:49 AM
Thank you very much. wish you were here to help get it done.
Old Jun 10, 2019 | 05:57 AM
89brokendownEF's Avatar
I changed my ignition out because I was having problems with key, got a used one with key but then I had to have honda program new key to my computer. Mines a 2000 u cant start it with a screwdriver
Old Jun 10, 2019 | 08:36 AM
Can I swap the fuse at night and just leave key in ignition or does cylinder need to be taken out?
Old Jun 11, 2019 | 04:09 AM
Buy a new lock mechanism with key, car-part.com u kind find used one cheap install it but leave old one plugged it, drive it to honda unplug old one and plug new one in in their parking lot. Then pay them 50 to match new key to your computer. This is what I did.
Old Jun 30, 2019 | 04:28 PM
Is there a part missing something that goes over or connects to that circle part
This is a96 integra. It was stolen we got it back . Is there something? missing any parts missing. Thank you
And if so can I drive it like this or no better not
Old Jul 9, 2019 | 02:36 PM
Carrjak's Avatar
Idk if you figured it out yet, but you're missing your air filter there, the big black hose that leads to a big black box. And I accidentally inserted my 96 Integra key into my 99's ignition (and it f'ing started, easiest car to steal and probably how yours was stolen) and it wouldn't come back out. I tried twisting really hard but it didn't work, I tried putting the key forward (without starting) and cycling the gears (automatic) P through 1st then as soon as I put it back into park I twisted it back and it let it out. I also ended up being my 96 key, unsure if that helped release it, but it still starts my 96 as well
