Questing about rebuilding a d16y8?
Old Jun 1, 2019 | 12:44 PM
Hondabbydriver's Avatar
Default Questing about rebuilding a d16y8?
So I am thinking about buying a blown it old Honda Civic that is at least 1996 or newer. I was wondering do I have to drop the engine to actually rebuild is it pistons and rods and bearings do I have pull the engine out or is there a way to do with the engine still in the chasie? I was just wondering thank you. And if you have any tips please let me know.
Old Jun 1, 2019 | 01:01 PM
tony_2018's Avatar
Fish Twig
Default Re: Questing about rebuilding a d16y8?
depends on what kinda of rebuild we're talking about.
Old Jun 1, 2019 | 07:49 PM
basket if the engine is knocking and im buying a rebuild kit? like replacing the bearings and stuff?
Old Jun 1, 2019 | 08:21 PM
muellersfan's Avatar
Pull the engine and put it on a stand. You won't know what you are up against until you tear down the motor and make the many required micrometer and dial gauge measurements on the block and head.
Old Jun 1, 2019 | 08:24 PM
Freedo_Civegra's Avatar
These engines are easy to remove in just a few hours.
Old Jun 1, 2019 | 08:41 PM
So true. I now remove the engine and transmission as a unit when I need to replace the clutch on my Civic. Thanks Honda!
Old Jun 1, 2019 | 09:43 PM
ok cool thanks so much
Old Jun 4, 2019 | 02:58 AM
NVturbo's Avatar
O.G. triple O.G.
and you don't even need to use a cherry picker to remove/re-install the engine. Just 2 good floor jacks, proper tools and knowledge.
FabianAlegre
Nov 1, 2015 02:09 PM
Mahalaleel
Apr 26, 2012 06:33 PM
patrickd_21
57
May 30, 2007 07:03 AM
.Kevin.
Feb 13, 2005 06:55 PM
