y7 harness y5 motor
Old May 27, 2019 | 01:55 PM
wsc_will's Avatar
Default y7 harness y5 motor
i have a d16y5 motor and p2p ecu with a d16y7 harness. my question is; is the reason my car wont pass 3500 rpm in any gear because i have a y7(non-vtec) harness with a vtec motor and ecu? just want to make sure im seeing this situation right
Old May 27, 2019 | 03:01 PM
mk378's Avatar
Default Re: y7 harness y5 motor
You have to have all the VTEC-E parts to make a HX package run properly. You can't swap them with other models. The P2P is the wrong ECU for the D16Y5, it is for a regular VTEC engine not VTEC-E.
With that said, you might want to check your cam timing, not revving over 3500 is often because of that. It might then run a little better but still will not be right.
namewasdallas
May 29, 2011 04:58 PM
wykedstyles
Jan 31, 2009 03:04 PM
illassek9
Sep 29, 2007 08:57 PM
dashskier540
13
Oct 24, 2006 11:54 AM
MINIMOKE1977
May 5, 2004 05:13 AM
