So i just bought a honda. 97 accord ex-r canada car i suppose. 4 cylinder vtec auto. I press the brakes it goes to the floor. No leaks under.. Could it be my master cylinder is out? Thanks in advance
Easy check.
With the engine off pump the brakes til the assist is gone and the pedal firms up, keep normal pressure on the pedal. Turn the engine on, if the pedal drops to the floor with the engine on then the BMC internal seals are leaking.
If the pedal doesn't change at al, verify there is fluid in the BMC if there is and the BMC is older it is most likely blown as well.
Unless the BMC is new or appears new, over-stroking the BMC usually damages the seals and will need to be replaced.
Easy check.
Originally Posted by Justin02Accord
It could, but also might just have air in the system and needs to be bled. I'd check that & fluid level first.
Hey there guys its the same guy had to remake another account.. So i guess the guy i got it from said his son had to panic break and i guess ever since then its been to the floor. I took the master cylinder off pushed the piston and it shoots out fluid. I popped the vaccum off the booster and it popped off so im assuming good vacuum.. Idk what it is.. Has 4 wheel discs
