Honda Accord starts but cut off
I have a 98 Honda Accord that sometimes starts and cuts off when it does run, I replaced , distributor, crank sensor, alternator, fuel pump and main relay ! NEED HELP ASAP !!
MM Gruppe B
Re: Honda Accord starts but cut off
When the engine dies, is it easy to restart the engine?
When the engine dies, do the gauges also die?
With the engine running, wiggle the key, does this cause the engine to stumble or die? Do you have lots of keys or charms on your key chain?
If any or most of these occur I would suspect the ignition starter switch is at fault. ~$30 at rock auto. This is the electrical switch, not the key tumbler. Fairly common for it to begin to fail in older Accords.
I mean sometimes the engine will turn over and no start and sometimes it will start and run for about 5 seconds and die out. And when I give it gas while it’s running the car would just die instantly. I have a strong battery and all my lights are working properly
whoatommy
12-23-2012 12:21 AM
