Can a stock B20B non vtec use hondata?
Old May 22, 2019 | 04:17 PM
DC4_LP's Avatar
Default Can a stock B20B non vtec use hondata?
Can a stock non vtec block be tuned on hondata with out turbo?
Old May 22, 2019 | 05:48 PM
ontariorider's Avatar
Default Re: Can a stock B20B non vtec use hondata?
Yes.
Old May 22, 2019 | 05:50 PM
wunfstgsr's Avatar
Loved
Community Favorite
You bet your ***!
Old May 22, 2019 | 06:22 PM
DC4_LP's Avatar
How? With just a ECU with hondata? And do I have to take it to a dyno?
Old May 22, 2019 | 06:34 PM
tony_2018's Avatar
Fish Twig
With an viable obd1 ecu that has an s300.
Old May 22, 2019 | 07:22 PM
wunfstgsr's Avatar
Loved
Community Favorite
You can Contact http://www.phearable.net/ and they can provide you with the correct OBD1 ECU and they can install the Hondata in the ECU as well as give you a base line or pre tune calibration for whatever mods you have on the engine, If the engine is stock I have no idea why you would want a Hondata but if you have say a intake, header, cams, exhaust ect, you list the modifications and they will setup the Hondata to run the engine safely, this is not a full dyno tune or close its just a few calibrations that will run the engine fairly well, in fact im on a base map for my Supercharged setup from them, Knock on wood the Hondata S300 works perfect on my setup im on 9 psi of boost and I have a few mods im going to do before I have a tuner take over and fine tune the engine but I have been driving the car for over a year with the Hondata ECU they provided me, so no you don't have to go the dyno after but its always a good idea to have it fine tuned.
Gearhead559
Engine Management and Tuning
Nov 16, 2008 07:34 AM
NoVtecLs
Oct 6, 2004 05:54 PM
,Kazi
Apr 7, 2004 08:51 AM
Ruby Civic
Sep 23, 2002 05:02 AM
Agamemnon
Oct 10, 2001 04:10 PM
