Transmission & Drivetrain Gearboxes, Differentials, Clutches
Adding LSD China Grip in LS transmission
Old May 16, 2019 | 07:10 PM
Lord Orange's Avatar
Default Adding LSD China Grip in LS transmission
So after many years of lurking I decided to post. In stead of buying an Mfactory diff, what is 2 China grips for 29.82 shipped. Pictures to come.
Old May 16, 2019 | 07:11 PM
Default Re: Adding LSD China Grip in LS transmission
Dont forget your little *****
Old May 16, 2019 | 07:54 PM
The part number for the pin.
Old May 16, 2019 | 07:56 PM
Driving pin out, and having the fall from bench to floor
Old May 16, 2019 | 08:09 PM
China grip wont fit. Must grind gears.
Old May 16, 2019 | 08:19 PM
Notice how much needs to be ground down to get the space to fit the box.
Old May 16, 2019 | 08:21 PM
Old May 24, 2019 | 06:48 AM
BoostHatchFreak's Avatar
one question. why not just grind the sides of the "lsd" down.
Old Jun 2, 2019 | 08:50 AM
Had to remove ring gear. Lefty tighty, righty loosey.
Still doesn't fit
grip fits but the pin does not
Grinding away
hardest part. make sure the gold 10mm bolt stays in that location.
installed
pin has to fit
Old Jun 2, 2019 | 08:55 AM
have to have enough clearance for the cross pin. keep grinding.
Old Jun 2, 2019 | 08:56 AM
All in all about 4 hours of playing with to get transmission together. Once I get it installed we will see how good the china grip is.
Old Jun 2, 2019 | 01:46 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I’m curious
Old Jun 3, 2019 | 11:38 AM
Prudz_lude's Avatar
What am I reading?
Old Jun 3, 2019 | 12:02 PM
2x0's Avatar
2x0
10 Year Member
Old Jul 2, 2019 | 02:42 PM
On the dyno at Richtune in Tacoma Washington, this LS transmission withstood 300 whp, and 202 wtorq (only 6.5 lbs of boost, b20 damper going on next, then retune). 2 tire fire outside of the shop (very streetable, almost raped ape). Not to bad for 12$ for the china grip, 11$ for the Pin, and silicone. They do make some clicking noises while turning but other than that. cheap alternative than spending on a 800$ diff plus installation.
Old Jul 5, 2019 | 01:54 PM
D21X's Avatar
How is it in the corners? Will both wheels get power or does the inside tire spin like crazy?
Old Jan 1, 2020 | 04:44 PM
jfboy's Avatar
How has this cheap LSD mod been holding up for you?
Old Jan 1, 2020 | 05:35 PM
Put it behind a dyno tested 300 hp kraftwerks supercharger EM1. Little bit of chatter but definitely better than open differential. No issues. 2 tire fire.
Old Jan 1, 2020 | 09:17 PM
jfboy's Avatar
This setup the spyder gears rub directly on the china locker unit.
since it rubs metal on metal, doesn't it cause metal shavings to Contaminate your oil over time?
I have seen other designs where you have a little friction disc there.
Old Jan 3, 2020 | 07:20 PM
Aquafina's Avatar
Yes, you are introducing metal shavings to clog up your passageways and cause damage to gears. The other design you speak of is the original that Phantom Grip poorly knocked off, the OPM. It utilizes clutch discs but is no longer made.
sixfourkiller
May 23, 2009 07:29 AM
COLORPROS
Apr 11, 2005 07:55 AM
2002desertsilver-rsx
Jan 7, 2002 11:50 AM
