Boosted del sol
Old May 16, 2019 | 05:09 PM
Justintylor1's Avatar
Default Boosted del sol
I have a 1994 del sol b18b1 swapped built bottom end car will fire and idle but as soon as you give it throttle barley revs up then starts to die out so far I’ve changed throttle body map maf iac checker timing 3 times 3 different ppl fuel pump as well and rebuilt dizzy even tried someone else’s.. I’m stumped so is everyone else! HELP!
Old May 16, 2019 | 07:03 PM
muellersfan's Avatar
Default Re: Boosted del sol
Post all of the CEL codes.
Are you able to set the ignition timing dead on?
Old May 16, 2019 | 07:08 PM
No codes at all.. and I can set the dizzy where it’s suppose to be yes that’s about it
Old May 16, 2019 | 07:23 PM
Does the CEL work?
What ECU is running the engine?
Old May 16, 2019 | 09:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Where is your "maf" located ???
Old May 17, 2019 | 04:53 AM
Maf is on the throttle body and the car is on hondata v3
Old May 17, 2019 | 04:54 AM
Cel does work yes!
Old May 17, 2019 | 05:24 AM
Tuned for boost?
Old May 17, 2019 | 05:49 AM
Yes it’s on e85 also fresh fuel too car ran perfect before this
Old May 17, 2019 | 08:04 AM
NVturbo's Avatar
O.G. triple O.G.
MAP sensor...not MAF sensor....two different things.
MAP -- manifold absolute pressure, at throttle body or intake manifold
MAF -- mass air flow, usually found on intake tube
Old May 17, 2019 | 08:11 AM
I have no maf lol I have a map? You think the map is bad I never changed it
kirkfreeman
11
Apr 4, 2015 09:31 AM
splashy
Apr 1, 2014 11:13 AM
blazianasian06
Feb 15, 2011 07:07 AM
Hmotorsol
Nov 18, 2006 06:11 AM
