Boosted del sol
I have a 1994 del sol b18b1 swapped built bottom end car will fire and idle but as soon as you give it throttle barley revs up then starts to die out so far I’ve changed throttle body map maf iac checker timing 3 times 3 different ppl fuel pump as well and rebuilt dizzy even tried someone else’s.. I’m stumped so is everyone else! HELP!
Re: Boosted del sol
Post all of the CEL codes.
Are you able to set the ignition timing dead on? |
Re: Boosted del sol
No codes at all.. and I can set the dizzy where it’s suppose to be yes that’s about it
Re: Boosted del sol
Originally Posted by Justintylor1
(Post 51932770)
What ECU is running the engine? |
Re: Boosted del sol
Where is your "maf" located ???
Re: Boosted del sol
Maf is on the throttle body and the car is on hondata v3
Re: Boosted del sol
Cel does work yes!
Re: Boosted del sol
(Post 51932893)
Re: Boosted del sol
Yes it’s on e85 also fresh fuel too car ran perfect before this
Re: Boosted del sol
(Post 51932893)
MAP -- manifold absolute pressure, at throttle body or intake manifold MAF -- mass air flow, usually found on intake tube |
Re: Boosted del sol
I have no maf lol I have a map? You think the map is bad I never changed it
