View Poll Results: How many batteries?
One for the entire car
0%
Two for the car and stereo system (separate)
0%
Voters: 0. You may not vote on this poll
Choosing the Correct Battery(s) For my Audio System
Old May 16, 2019 | 04:59 PM
Haws's Avatar
Icon5 Choosing the Correct Battery(s) For my Audio System
Hi, before you read I'd like to say any help at all would be greatly appreciated.
Problem #1: Should I:
1. One battery to power the entire vehicle and Audio System
2. Two batteries to power the vehicle and Audio System (one battery for each)
  • If so, do I hook these up in series?
Problem #2: Depending on your answer from problem 1, what battery specs should I be looking for? I know what can run my car (1990 CRX B16B swap), but what about the subs, Wattage, peak current, CCA, ect.
Note: Space is not an issue! Seriously, I have plenty of space (I moved all electrical cables to the trunk and have built an adjustable mount).
Here is my audio setup:
Sorry for the horrific picture (wtf am I looking at?)
x1 Kenwood XR900-5
x4 ARC AUDIO 2-Way Crossover Network 12dB/Oct.
total estimated audio wattage ~=1200W ??
So what battery did I have before??
This battery was running both the car and audio system before. I did have problems with it though. If I cranked the volume too loud, the subs would "crash" and audio would cut off. I would have to restart the stereo for it to turn back on. Only reason why I suspect the battery being the issue is because the lights would dim when the bass would hit.
Why don't I use this battery? It doesn't work, for some reason I went to charge it and it blew up!
Again, any help at all would be greatly appreciated. Thank you!
Old Jul 20, 2019 | 05:31 PM
94_DC4's Avatar
Default Re: Choosing the Correct Battery(s) For my Audio System
Look for a high output alternator
komodomoe
Audio / Security / Video
May 12, 2013 07:41 PM
Michael.K.Conte
Jun 6, 2010 06:32 AM
ezza
Mar 4, 2009 05:37 PM
LudemanDan
Jun 7, 2005 10:53 AM
CivicSk8ter
Feb 22, 2002 02:32 PM
