I have a 92 cx hatch and I‘m currently rebuilding the suspension. I found an integra partout so I was thinking of getting the front and rear lcas and sway bars along with the rear disc conversion. I know I have to swap out the lcas, but ither than that will the front and rear sway bars fit fine? Like does the cx have the holes in the subframe to mount the sway bars to? Thanks
The CX does have holes in the subframe, but they are to mount brackets to. Then you mount the sway bars to the brackets. You can use Si brackets, I made my own. At least that is how my 99 Si and 94 VX are.
Exhaust may also be an issue with the Integra sway bar. When I put an Integra sway bar in my Si, I had to cut and weld and remake the sway bar ends (PITA). No pic.
I would just use the integra brackets and buy good bolts for the rear, the holes should be in the subframe, you will need the integra lca
for the front you will need the teg lca as i don't think the cx had the mounting holes for thebar on the lca, but since its a 92 it might, just like all 92 regardless of trim had vtec wiring from the ecu to the shock tower
for the mounting brackets on the front, the holes are probably there just buy good nuts and bolts
