Suspension Techniques sway bar for 92 CX.
I'm trying to install some ST sway bars (F&R) on a 92 CX. I've paid for the car, but haven't taken delivery so please pardon some of the questions that I should obviously know if the car was in my possession. Does the car come with either a front or rear sway bar? (I've heard that it comes with a front but no rear, no front AND NO rear, etc.). Just want the honest truth on this.
Do I need to do anything to mount their front an rear sway bars? Do I need to get different LCA's or anything like that? On my 00 Civic Si and 01 ITR (I don't have these cars anymore), the sway attached to the LCA's. But someone told me that the rear LCA's aren't even threaded for a rear sway. Thanks for the help.
p.s. I tried searching, but you get TOO much information when searching for sway bars in the EG+ forum...
Re: Suspension Techniques sway bar for 92 CX. (kf_Type-R)
The 92 CX does not come with a front sway bar. I believe the only EG hatchback to come with a front sway bar was the SI. The S/T kit is designed to be a bolt on for your car, meaning you will not need to purchase any extra parts. The only modification necessary is drilling two holes in the rear subframe to mount the bushing brackets for the rear sway bar. Detailed directions come with the S/T sway bar kit, so no need to worry.
Re: Suspension Techniques sway bar for 92 CX. (laz74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laz74 »</TD></TR><TR><TD CLASS="quote">The 92 CX does not come with a front sway bar. I believe the only EG hatchback to come with a front sway bar was the SI. The S/T kit is designed to be a bolt on for your car, meaning you will not need to purchase any extra parts. The only modification necessary is drilling two holes in the rear subframe to mount the bushing brackets for the rear sway bar. Detailed directions come with the S/T sway bar kit, so no need to worry.</TD></TR></TABLE>
what he said. the only thing I'll add is they make kit's for car's with and with out front sway bars. But where ever you order from should have this info as long as you tell them exactly what kind of car it is
Re: (mrnicolas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnicolas »</TD></TR><TR><TD CLASS="quote">so to sum it up a 93 cx also does not have afront sway bar?
Cx= no front or rear sway bar.
Yellow Dragon
04-07-2003 05:21 PM
