What is this line for?
Old May 13, 2019 | 04:41 PM
redlobster's Avatar
Default What is this line for?
Recently bought a 98 accord 4cyl auto, found this line capped off with a screw. What does this line go to?
Old May 13, 2019 | 05:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: What is this line for?
That is the vacuum hose from the engine mount control solenoid valve.
  1. The engine mount control system comes on Accords with automatic transmissions. It is used to control excessive vibration at low rpms (e.g. idle). At low rpms, the PCM sends a ground signal (-) to the engine mount control solenoid valve, which opens the valve.
  2. If the engine mount was replaced before with an aftermarket solid mount, then they may be why it is disconnected and capped. (Aftermarket has both solid rear mounts and vacuum assisted rear mounts for replacement.)
Old May 13, 2019 | 06:34 PM
redlobster's Avatar
wonder if that’s why the accord has stronger than normal vibration at idle
Old May 14, 2019 | 03:08 PM
MAD_MIKE's Avatar
MM Gruppe B
Stopped in drive the car will vibrate quite a bit. Steering wheel will vibrate. If you brake and gas a bit to raise the idle speed and the vibration goes away, then it is most likely an MT mount or 'solid' AT mount.
T.L.
Nov 15, 2017 08:04 AM
peterkemp47
Jul 30, 2016 11:03 AM
Slowbro
Jan 9, 2015 07:49 PM
edogmb
Nov 10, 2010 12:42 PM
bdmlilburn
May 5, 2009 07:09 AM
