What is this line for?
Re: What is this line for?
That is the vacuum hose from the engine mount control solenoid valve.
- The engine mount control system comes on Accords with automatic transmissions. It is used to control excessive vibration at low rpms (e.g. idle). At low rpms, the PCM sends a ground signal (-) to the engine mount control solenoid valve, which opens the valve.
- If the engine mount was replaced before with an aftermarket solid mount, then they may be why it is disconnected and capped. (Aftermarket has both solid rear mounts and vacuum assisted rear mounts for replacement.)
MM Gruppe B
Stopped in drive the car will vibrate quite a bit. Steering wheel will vibrate. If you brake and gas a bit to raise the idle speed and the vibration goes away, then it is most likely an MT mount or 'solid' AT mount.
Slowbro
01-09-2015 07:49 PM
bdmlilburn
05-05-2009 07:09 AM
