Suspension & Brakes Theory, alignment, spring rates....
caster settings for EF track car
Old May 13, 2019 | 10:32 AM
zcwagon's Avatar
Default caster settings for EF track car
Hey
having high speed stability problems with our EF track car. At the end of any long straight the car starts darting back and fourth, Camber is 3 deg neg up front and 3.5 in the rear. Toe is 1/16" toed in in front 0" rear. Just removed our stock from cross member and installed the Innovative Mounts unit but we are also using King Pins spherical bearings front radius rod bearings. I want to check the cast or add as munch as possible to see if that solves the problem. Anyone know the stock specs for caster on the 1991 hatch?
Can anyone confirm this may be the cause of the high speed instability
Old May 20, 2019 | 02:50 PM
Tyson's Avatar
Default Re: caster settings for EF track car
id change to:
front 1/16 toed out
rear zero toe.
i dont think your caster would matter going straight.
SleeiNESS
Feb 4, 2012 08:30 AM
Deo
Sep 19, 2007 06:49 AM
brokenojoke
Jun 19, 2007 06:55 AM
^AnDre^
Suspension & Brakes
Oct 26, 2005 11:02 AM
