Camber setting. Front different than rear in EF?
I searched for the best starting point for my camber setting on EF.
Running GC/Tokico Illumna with 400f/450r
Car is track only
Will be running Dot "slicks", Falcon Azeena currently
-2.5 is the average starting point i've found most people using in front. I've never seen anything about rear. Should it be the same?
Car is track only
Re: Camber setting. Front different than rear in EF? (brokenojoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenojoke »</TD></TR><TR><TD CLASS="quote">-2.5 is the average starting point i've found most people using in front. </TD></TR></TABLE>
Depends on the tire. Toyos like -3 to -5.
Rear is a compromise, depends on how you need to balance the car. Maximize the front traction and adjust rear to compensate.
Re: Camber setting. Front different than rear in EF? (Chris F)
A little off the subject, but as far a toe, 0 all around seems to be the general answer. Again, car is only track driven.
Any other opinions?
Any other opinions?
Re: (Lo-Buck EF)
205's barely clear now. 225's are on order though.. I guess if the camber gets too carried away, I'll roll the fenders a little.
Good thing I didn't get the 35 offset wheels.... then again I have 5mm spacers with extended wheel studs I was going to put on. Maybe not....
Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF »</TD></TR><TR><TD CLASS="quote">since its a track car, youll be running 225s all the way around. </TD></TR></TABLE>
this guy can barely spell the name of the tires hes running
doubt hes running fat boys!
225's
camber setup should depend upon track ultimately
225's
Re: (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brokenojoke »</TD></TR><TR><TD CLASS="quote">205's barely clear now. 225's are on order though.. I guess if the camber gets too carried away, I'll roll the fenders a little.
no, your gonna have to get in there and roll that lip totaly flush with the inside of the rear quarter to even begin to think about fitting 225s. 38-40 offset works best btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">
225's
camber setup should depend upon track ultimately</TD></TR></TABLE>
LOL!! Yes, camber settings are track dependent.
225's
