Don’t know what this piece is
Old May 12, 2019 | 05:07 PM
jharvgsr's Avatar
Default Don’t know what this piece is
I replaced my valve stem seals with the head on the engine. I also removed my upper intake manifold, vtec solenoid and egr valve. While putting car back together I found this piece on the ground. Could anyone tell me what it is, it would be greatly appreciated. 2000 Honda Accord lx 4cyl f23a
Old May 12, 2019 | 08:27 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Don’t know what this piece is
That looks like the cap on top of the spring for the LMA(lost motion assembly) to keep the VTEC rocker floating when not engauged. Note the cap on the spring.
This is the LMA off an H22, but the parts on an F VTEC engine are about the same.
Old May 13, 2019 | 06:10 AM
jharvgsr's Avatar
I appreciate the response but it’s not from the LMA, it’s smaller then that. Here’s a pic next to quarter to get an idea of the size, it’s almost the size of the dowels.
Old May 14, 2019 | 10:06 AM
LeeMajors19082's Avatar
10 Year Member
Just a guess, cause I haven't had one apart in awhile, but could it be one of the float pins from the vtec solenoid?
Old May 14, 2019 | 03:05 PM
MAD_MIKE's Avatar
MM Gruppe B
Recheck your rocker arms and that all of them have their piston assemblies installed.
If you didn't rubber band them together during disassembly the piston may have popped out.
Old May 18, 2019 | 10:04 AM
jharvgsr's Avatar
Thanks for the help, it ended up being one of the synchronizing pins/pistons on the primary rocker arm assembly
Old May 20, 2019 | 07:14 AM
jharvgsr's Avatar
Closer inspection seems 2 fell out and I only found one. Of cours nobody sells just the timing piston so I’m trying to find used head or rocker arms if anyone can point me in the right direction.
Old May 20, 2019 | 09:27 AM
MAD_MIKE's Avatar
MM Gruppe B
Use a pencil magnet down the oil return holes in the head. It may have even fallen down into the oil pan.
Old May 27, 2019 | 07:20 AM
jharvgsr's Avatar
Thanks for the suggestion mad_mike but I already dropped the pan and checked the oil returns. I was able to get a used cylinder head for 100 so I’ll have what I need in a few days.
justdon201
Jul 16, 2015 09:07 AM
2accrds
Feb 10, 2010 05:50 AM
itismejoshy
Mar 29, 2007 10:34 AM
sauceja
Feb 24, 2006 07:46 PM
