Going from Peak and Hold to Saturated?
Old Nov 14, 2002 | 11:30 AM
satan_srv's Avatar
Default Going from Peak and Hold to Saturated?
Okay so I had peak and hold injectors with the external resistor box. If I put a motor in with saturated injectors, I know I don't need the external box...but how do I hook up the new injectors? Will I need to cut and splice wire from the 5 wires going to the box and rerout them to the fuel rail?
Thanks again...h22a if it matters
Old Nov 14, 2002 | 03:15 PM
Perfectionist's Avatar
Default Re: Going from Peak and Hold to Saturated? (satan_srv)
The injectors get power all the time. the ECU completes the circuit to ground. The P&H injectors require a resistor, so Honda uses one for each injector. That's why there's so many wires. For saturated injectors, I don't see why you can't just run one wire to them all. Someone please correct me if I'm wrong here. Thanks.
Old Nov 14, 2002 | 07:06 PM
Pelican's Avatar
Default Re: Going from Peak and Hold to Saturated? (Perfectionist)
Try this, straigh from Hondata
So it looks like one 12V would work
[Modified by Pelican, 11:07 PM 11/14/2002]
Old Nov 15, 2002 | 06:12 AM
R@mon's Avatar
Default Re: Going from Peak and Hold to Saturated? (Pelican)
satan just pull the plug off the resistor and pull the pins out of the plug and join them all together. i have mine like that right now... however you want to do it. all you need to do is join all five together and it will work....
im running a h22a4 in my 93 si w/sat. injectors
[Modified by 93h22a4, 7:13 AM 11/15/2002]
tarheelsoldier
Jan 10, 2007 08:13 PM
lshatch59
Jan 7, 2007 08:01 AM
91preyludesi
Dec 26, 2006 06:25 PM
nick91civicsi
Aug 21, 2006 05:15 PM
d16racer
Mar 7, 2006 03:19 PM
