Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic 2004 LX front crankshaft oil seal remove and replacement cost
Old May 10, 2019 | 10:19 AM
siva_s's Avatar
Icon6 Civic 2004 LX front crankshaft oil seal remove and replacement cost
Hi,
When I took my car(Honda civic 2004 LX 1.7L) which ran for 94K for oil change, mechanic told there is a little oil leakage there in engine and he given quote for remove and replacement of Front CrankShaft oil seal. He quoted 320$ for labor and Part cost is 15$.
Can you please let us know is that cost is reasonable?
Old May 12, 2019 | 08:24 AM
hondandy's Avatar
Default Re: Civic 2004 LX front crankshaft oil seal remove and replacement cost
I wouldn't worry about it much. I have a little oil here or there on my d17 with about 175k. Use the high mileage oil that can help. That does sound kinda pricey if you do decide to have it fixed. Maybe get another quote. But if it's not dripping out on the driveway or smoking I wouldn't spend the money.
Old May 12, 2019 | 10:32 AM
stin1's Avatar
Loved
Community Favorite
These are usually done with timing belt and water pump service. Have you replaced the water pump and timing belt within the last 7 years?
Old May 13, 2019 | 06:28 AM
siva_s's Avatar
Yes, timing belt and water pump is replaced 5 years ago(2014).
Old May 13, 2019 | 06:34 AM
siva_s's Avatar
"I wouldn't worry about it much. I have a little oil here or there on my d17 with about 175k. Use the high mileage oil that can help. That does sound kinda pricey if you do decide to have it fixed. Maybe get another quote. But if it's not dripping out on the driveway or smoking I wouldn't spend the money."
Thanks for your response. Yes, It's not dripping out or not smoking. I just see oil spread around the engine.
Old May 13, 2019 | 11:28 AM
siva_s's Avatar
Is high mileage oil will fix this crankshaft oil seal if it is not dripping out?
Old May 14, 2019 | 08:58 AM
NDNV's Avatar
I don't think high mileage oil will help your oil leak. I wouldn't switch to a synthetic or lighter viscosity as well.
black0hatch
Feb 13, 2010 06:59 AM
gnccracer20
11
Feb 4, 2009 03:14 AM
medic4.life
Jul 16, 2007 08:02 PM
snatch
12
Mar 15, 2005 10:12 AM
jetlude
Aug 14, 2004 07:57 PM
