98 Accord front wheel hub replacement
Hi all, I just received my bearings and hubs. I understand I need to press the bearings onto the hub. But I can't find anything on removing or installing the hubs. Seems that everyone just pulls the knuckle off and presses out the old bearings and presses the new ones into the hub. Can I pull off the hubs and install the new hub with the bearings pressed in?
You will need a press. why did you buy new hubs? It is simple press out the old hubs then the old bearings and press the new bearings in to the knuckles then the hubs in to the bearings and put back on the car.
charliecd5
Feb 12, 2015 06:01 PM
Bnjmn
Sep 20, 2005 03:43 PM
