Unknown wires under 93 Del Sol dash
Old May 8, 2019 | 09:15 AM
YeehawDawg's Avatar
Default Unknown wires under 93 Del Sol dash
I removed an aftermarket steering wheel, and about have the stock steering wheel all hooked up. All wires for lights, wipers, cruise, horn, and airbag are accounted for. However there are a few wires below the steering column unaccounted for:
Two connectors with two pins each.
One connector with four pins.
One connector with five pins.
One connector with eight pins.
Any idea what any of these connectors are for? Thank you.
Old May 8, 2019 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Unknown wires under 93 Del Sol dash
An aftermarket alarm system. You can ignore them.
Old May 8, 2019 | 08:39 PM
tony_2018's Avatar
Fish Twig
Old May 9, 2019 | 06:43 AM
YeehawDawg's Avatar
Thanks for your response, and ok cool. So I assume this button is just part of that aftermarket alarm too? I can't find anything about it online, so it appears to not be stock.
Old May 10, 2019 | 05:34 PM
mk378's Avatar
Yes that is also not stock. If you follow the wires from that switch they are likely some of the ones in your first post. You can remove all of that stuff.
Eddie 70
Feb 21, 2011 09:01 AM
typac69
Sep 1, 2008 01:38 PM
Frost_1097
Jan 16, 2007 03:48 PM
