Unknown wires under 93 Del Sol dash
https://cimg9.ibsrv.net/gimg/honda-t...258e07db77.jpg
I removed an aftermarket steering wheel, and about have the stock steering wheel all hooked up. All wires for lights, wipers, cruise, horn, and airbag are accounted for. However there are a few wires below the steering column unaccounted for: Two connectors with two pins each. One connector with four pins. One connector with five pins. One connector with eight pins. Any idea what any of these connectors are for? Thank you. |
Re: Unknown wires under 93 Del Sol dash
An aftermarket alarm system. You can ignore them.
https://cimg0.ibsrv.net/gimg/honda-t...2f78744312.jpg
Originally Posted by JRCivic1
(Post 51927031)
Thanks for your response, and ok cool. So I assume this button is just part of that aftermarket alarm too? I can't find anything about it online, so it appears to not be stock. |
Yes that is also not stock. If you follow the wires from that switch they are likely some of the ones in your first post. You can remove all of that stuff.
