Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2014 Accord v6 - two issue
Old May 7, 2019 | 02:00 PM
DVIR99's Avatar
Default 2014 Accord v6 - two issue
Hello everyone I'm new here
first thing my accord very close to 100K miles, its time to replace timing belt, any recommendations witch part to purchase Genuine Honda OEM
Parts only or there is aftermarket parts that good enough that work good as the OME parts? on the way witch parts necessary replace also?
second thing that disturbing me long time a go, i have some problem with my starter, some times the starter not starting and making a noise of creak, i can say approximately 1 of 15 times its happen
I replace a starter already but the problem not solved, anyone have idea what is the problem if its not the starter?
last thing if anyone can recommend a good mechanic that experts on Hondas, I'm from bayside, Queens, NY area.
i don't want pay again hundred dollars for nothing.
Thanks!!
Old Jul 3, 2020 | 01:24 PM
gearsdown's Avatar
Default Re: 2014 Accord v6 - two issue
I have used Rock Auto, AISIN kit with belt and water pump was recommended to me.
Look up Technical Service Bulletin 16-002
Reference Number(s): 16-002 Version 3, Date of Issue: August 11, 2017
HONDA: 2013-2016 Accord; 2013-2015 Crosstour Superceded Bulletin(s): 16-002, Date of Issue: February 11, 2017
"The starter grinds or spins at startup."
Honda replaced my starter out of warranty(barely) under their Good will program.
Thanks!!
Old Jul 6, 2020 | 11:10 AM
Quicksight87's Avatar
2014 accord has a timing chain not a belt....am I right?
Old Aug 11, 2020 | 03:38 PM
My2014Honda's Avatar
what is the voltage of the battery? sometimes if the battery is beyond useful lifetime (5 years) it will not hold a charge and it will cause the starter to work harder. See how old the battery is first.
kv1
Aug 18, 2019 08:00 PM
Cstanis
Aug 28, 2018 07:42 AM
dave98
Oct 20, 2014 08:35 PM
SQ is the SQUAD
Jul 18, 2011 06:49 AM
jlainc
Jun 14, 2004 10:59 AM
