Alignment after lowering springs
1997 accord 2.2..i searched numerous posts and conflicting answers..im installing eibach prokit with 1.2" drop..some say not needed bit others say mandatory..what do you guys think..much appreciated..thanks
It depends on the car and how the suspension was designed and how much bump steer is built in. It has been my experience with my 94 EX that when I lowered it a little over an inch, the insides of the tires wore very quickly. When I adjusted the toe-in, it stopped the wear. Even a car that has not been lowered needs the toe-in adjusted periodically.
When I was a dumb kid I put 2" lowering springs on my car and didn't bother with an alignment because it "wasn't necessary". I completely destroyed the inside tread of brand new tires in a little over an oil change interval. Get an alignment like Fitz said. Any time you change or make any adjustment to the suspension in these cars an alignment is required.
If it's substantially cheaper at your local shop you can probably just get by with a front end alignment. Typically the rear will toe-out a little with a drop and it's not that much of an issue. The front will always toe-in though and it's a problem.
FWIW, I played around with the suspension settings a lot, and obviously didn't want to get an alignment every time I made a change. So I went to the hardware store and bought some angle aluminum and made my own toe-in adjuster. I would measure the distance between the front and rear of the rims, right to left, and adjust accordingly. Really old school, but it works. I once built and raced cars on the SCCA circuits, so I was used to doing things like that. Not really hard at all. And you can build a camber tool too, if you have a way to adjust the camber.
PhatRoyale
Suspension & Brakes
13
Oct 8, 2008 07:58 PM
