Broke off a peice of metal on the inside of the crankcase? picture included!
Old May 4, 2019 | 11:04 AM
bikerganglol's Avatar
Default Broke off a peice of metal on the inside of the crankcase? picture included!
broken piece of metal !
Old May 5, 2019 | 10:27 AM
Default Re: Broke off a peice of metal on the inside of the crankcase? picture included!
will this effect my oil pressure and ruin the engine or route the oil to the wrong place??
Old May 5, 2019 | 06:05 PM
bump
Old May 7, 2019 | 12:01 PM
1990IntegraLS's Avatar
Did you lose the piece that goes there? Sometimes you can braze it back. I don't know how that'll effect the oil. What does the outside cover look? Is it part of oil channel or is it closed.
Just curious, how that happened.
Old May 7, 2019 | 06:17 PM
i still have the peice and what do you mean braze it? its closed in that surface to the case so im pretty sure i ill have to tac it in place or who knows what would happen to the engine
Old May 7, 2019 | 07:48 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
If you tear that crankcase apart that piece can be welded back on just fine.
Old May 7, 2019 | 08:10 PM
ill clean it good and cover up the gears from splatter with rags and get a shop to weld it to lazy to remove everything
Old May 8, 2019 | 01:18 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
You won't have room to weld it if the gears are there.
Old May 8, 2019 | 04:56 AM
If you don't do this the right way, the chances of loosing the engine are high.
smelldaOdaa
Apr 14, 2009 01:52 PM
vietkangta
Mar 27, 2008 11:44 AM
QCKGSR
Oct 22, 2005 02:52 PM
Lude S
Oct 24, 2004 04:27 PM
youngkow
Nov 28, 2002 10:42 AM
