It says "DENSO uses ND-oil 8 for its R134a type refrigerant compressors, a PAG 46 oil."
I'm doing an evac/recharge of the system with the original compressor--which works perfectly--and I'm not keen on messing that up simply by dumping in the wrong viscosity oil. That said, I could just use 38897-PR7-A01AH and be done with it. But I'm also not keen on spending a bazillion dollars for OEM compressor oil when aftermarket of identical viscosity will suffice.
If you are just doing an evac and recharge I don't believe you need to add any oil. Only if you are replacing a part of the system. I do remember the FSM's from honda saying that for a few different cars that I have looked into. But they also don't specify how much to add when you replace the compressor, they just say to drain out the old one and subtract that from the total drained from the new one (or something like that, been awhile since I looked). lol
But they do give amounts for other components, like lines, evaporator, drier, etc..
I've got the Honda Service Manual handy... e'yup, you are correct on all counts. There doesn't seem to be specific language recommending adding oil as part of an evac/recharge. And sure enough, the HSM lists quantities for each system component--sans compressor, which uses the measurement procedure just as you mentioned. You've got a good memory!
The initial reason for my question: I intend to add UV dye during the recharge. I figured I'd use the combo UV dye/PAG-compressor-oil brew, and dump in the specified quantity. Turns out, it's a moot question: There's no spec.
