I need some help I bought a 2000 Honda Civic hatch shell it had no motor I put a y8 in it I didn’t have a wire harness for the engine so I found a 96 Honda Civic part out I took the harness the dizzy ecu everything I needed everything plugs in but we’re i connect the ecu there’s an extra plug it cuz the inside harness is from a 2000 wat should I do I also took the inside harness of the 96 civic should I change the inside harness to would it work lmk really need the help
