can i change ima for 02 sensor?
Old Apr 30, 2019 | 02:57 PM
ochumi's Avatar
Default can i change ima for 02 sensor?
I have a uncatalyzed D16A9 crx original ecu OBD0, is it possible to make that change?
I'm not sure but im getting error 11 that is from the IMA, the strange it´s im getting 11 fast blinker not 1 large and 1 short.... is it ok?
I have used these diagrams to make the change.
The 02 works between 0-1V, IMA works also in this range?
Old May 2, 2019 | 10:09 PM
ochumi's Avatar
Default Re: can i change ima for 02 sensor?
Old May 3, 2019 | 07:14 AM
4drEF's Avatar
Keyboard Humorist
I know nothing about the IMA sensor, but I found this.
https://honda-tech.com/forums/honda-...-11-a-3039965/
Appears the the IMA sensor is what you need. Not sure what region of the world you are in so sourcing an actual replacement IMA might be tough.
No idea if there there is a USDM O2 sensor that could be used as a replacement.
Old May 3, 2019 | 11:50 AM
jlicrx's Avatar
this is the PM7 ECU with IMA sensor - it is the black thing in the picture - this ECU will not support the O2 sensor - you would need the ECU for the cars equipped with catalytic convertor and O2 sensor
all OBDO D-series ECU's use only short blinks for the codes, i.e. 11 blinks = IMA, 17 blinks = vehicle speed sensor - no long and short blinks
Old May 3, 2019 | 12:03 PM
ochumi's Avatar
ok i can´t use this ecu for o2 it´s difficult to find the ima sensor... thanks also for short! maybe i will have to move to Obd1 and use a 02 sensor, i don´t what is better chipped ecu or hondata...
Old May 3, 2019 | 01:21 PM
jlicrx's Avatar
https://www.ebay.com/itm/ECU-ENGINE-...4AAOSwolpcE4E8
Old May 11, 2019 | 09:17 AM
ochumi's Avatar
hi
thanks i can fix with sensor position of the throttle but i have another problem with a d16a9
dez6
May 17, 2013 01:29 AM
craigmack14
Nov 2, 2009 05:08 PM
