Need help with 94 integra LS Auto
hello i apologies if this is not the correct forum but i need help with my 94 Integra LS , for a while the car started struggling to accelerate through 1st and 2nd gear then the car started to want to turn off while driving, recently the car died on me in the middle of the road and didn't want to turn on. after a while it started but struggled to move then died so i called a tow. now when i turn it on it idles very low and seems to want to turn off before revving back up again. the car has new spark plugs and distributor cap so at this point i am lost. also i noticed the smell of gas after trying to get it started again so maybe a fuel pimp or a relay? i am not a mechanic nor do i mess with cars all that often so if anyone can point me in the right direction i would appreciate it. without this car i am screwed
check the fuel lines under the car if they are leaking , they tend to rust out and I only mention this as you said that you smelled fuel. If you are getting proper fuel pressure then it may be the igniter or coil inside the distributor on the ignition side.
Did you ever notice the check engine turn on ever during these times? if so try and get the ECU scanned for any codes with a hand scanner. This will point directly to the problem.
Check all the electrical plugs and the wires for anything unplugged or pulled out the harness.
Could also be a bad Map sensor.
Meesterzoomak
Jan 25, 2007 04:25 AM
