Idle surging issue...and yes I searched before posting.
Old Apr 22, 2019 | 08:08 PM
Mecca8383's Avatar
Default Idle surging issue...and yes I searched before posting.
92 Civic LX with 309,000 miles, all stock except the CAI.
So my idle is surging from 500 rpms-700rpms when it gets warmed up(idle is fine and steady when car is cold).
I have cleaned the throttle plate and opening.
I have cleaned the IACV.
I checked my CAI filter, its clean, no debris, hardly any dirt in the pipe.
I have checked the coolant in the bottle and radiator..they are both full.
I even attempted to get whatever air bubbles out tonight if any(just in case).
One thing I did notice was when I was trying to get bubbles out(heat on blast, rad cap off, front of car tilted up a bit), I noticed when I turned the heat ON the idle surging would STOP..and then I turn the heat OFF the surging would START AGAIN. Is that a big clue?
I have Googled and Googled and can't find what to do next or what it means.
Please Let me know... Thank you
Old Apr 23, 2019 | 04:15 AM
mk378's Avatar
Default Re: Idle surging issue...and yes I searched before posting.
Warm up the engine, turn off the heater / AC, lights, radio etc. then unplug the IACV and check that the speed drops to much less than normal, about 450 rpm (this would be shaking a lot and almost stalling). Adjust the air screw to achieve this. If it cant be brought to a low speed with the IACV unplugged, find the air leak.
Unplugging the IACV will turn on the CEL with a code 14, this is to be expected.
BravoTango
Feb 27, 2020 06:14 AM
vrrodri
Aug 20, 2018 07:06 AM
KimvdLinde
Jun 29, 2013 01:40 PM
jah.tien
Jul 14, 2010 10:37 AM
byronl
Jun 14, 2006 08:26 PM
