Fred Conforto
Just an fyi on the accord issue where it is losing power and will not increase engine idle over 3 thousand rpm. I had to figure this out checking the operating systems individually.and in complete unison to help me diagnose what the issue was. In my case and I have. Since seen it several times it was the catalytic converter that were the issue the were clogged up causing the 02 sensors to trigger and put it in limp mode usually once car warmed up. Physically remove o2 sensor cap hole in converter on both sides and see if you do not regain full power , replace converters reassemble and o2 sensors if required but once codes are cleared your ser
Hello, to all I hope I can learn and absorb all I can from the people who have busted there heads and knuckles on these awesome machines. I would always recommend a honda to all my friends if they were to buy a new car not because I liked them at the time, I do now, but because they never really came through my bay for other than routine service so I finally drove a 2015 accord vtec 5 speed 4 cylinder and it blew me away I went out and bought a 03 accord coupe v6 vtec and I fell in live with that thing like a 50 year old kid
