1995 Accord v6 not starting question please.
Old Apr 21, 2019 | 12:37 PM
Jim Brady's Avatar
Default 1995 Accord v6 not starting question please.
Hi I have replaced neutral safety switch and key switch.
The car still intermittently does not click or nothing.
If I pull the stick down to the drive then back up in to park most times it will start when it gets back in to park. I really thought it was neutral switch. Any ideas would be appreciated. Both parts replaced with new parts.
Thank you
Old Apr 21, 2019 | 01:08 PM
JuicedUpRice's Avatar
Default Re: 1995 Accord v6 not starting question please.
Originally Posted by Jim Brady Hi I have replaced neutral safety switch and key switch.
Thank you
check battery terminals grounds and engine bay grounds for continuity with a multimeter..
does fuel pump prime? does main relay click after prime? is that the click you're talking about?
if so, and no click, I would suspect the ignition switch (not the key switch), and/or the main relay.
main relay is cheap, might as well just toss a new one in there..or resolder
ignition switch, I would check pins for if voltage goes to or from it
this post should help you with testing that
https://honda-tech.com/forums/tech-m...agram-2926002/
There is no click or any sound when trying to start it the dash lights do dim down. Battery is good yes it may be an ignition switch itself. Thank you
I was told there was no relay by parts store.
yea check ignition switch out, it should be a thick black heat wrapped bundle of cables on the opposite side of the key, and if you take off the white cap(if it has one), youll see the wires for the different connections that you can test with a multimeter.
Im almost positive that year accord has a main fuel pump relay just like my civic. If its not a relay, its a fuse..check around.
test first. then let us know
chaza
Jul 21, 2012 06:45 PM
jordan_rael_420
Dec 6, 2010 08:29 PM
t3to4e
May 17, 2010 03:33 PM
JONESER
Aug 21, 2008 07:44 PM
Redicliff@honda-tech
Nov 28, 2004 06:44 AM
