Thread was move to correct area
Old Apr 21, 2019 | 12:16 PM
Jim Brady's Avatar
Default Thread was move to correct area
has been moved to correct part of forum.
Old Apr 21, 2019 | 12:38 PM
JuicedUpRice's Avatar
Default Re: 1995 Accord v6 not starting question please.
Originally Posted by Jim Brady
Hi I have replaced neutral safety switch and key switch.
The car still intermittently does not click or nothing.
If I pull the stick down to the drive then back up in to park most times it will start when it gets back in to park. I really thought it was neutral switch. Any ideas would be appreciated. Both parts replaced with new parts.
Thank you
check battery terminals grounds and engine bay grounds for continuity with a multimeter..
does fuel pump prime? does main relay click after prime? is that the click you're talking about?
if so, and no click, I would suspect the ignition switch (not the key switch), and/or the main relay.
main relay is cheap, might as well just toss a new one in there..
ignition switch, I would check pins for if voltage goes to or from it
this post should help you with testing that
https://honda-tech.com/forums/tech-m...agram-2926002/
Old Apr 21, 2019 | 12:44 PM
Jim Brady's Avatar
Default Re: Thread was move to correct area
There is no click or any sound when trying to start it the dash lights do dim down. Battery is good yes it may be an ignition switch itself. Thank you
Old Apr 21, 2019 | 12:45 PM
Jim Brady's Avatar
I was told there was no relay by parts store.
hondalion
Jun 29, 2013 01:40 PM
jc95148
Audio / Security / Video
Dec 16, 2012 02:57 PM
andyvaj
Aug 15, 2012 09:44 AM
GS8HFL21
Nov 9, 2005 06:56 AM
Christine
Oct 3, 2001 07:44 AM
