Thread was move to correct area
has been moved to correct part of forum.
Re: 1995 Accord v6 not starting question please.
Originally Posted by Jim Brady
(Post 51914758)
Hi I have replaced neutral safety switch and key switch.
The car still intermittently does not click or nothing. If I pull the stick down to the drive then back up in to park most times it will start when it gets back in to park. I really thought it was neutral switch. Any ideas would be appreciated. Both parts replaced with new parts. Thank you does fuel pump prime? does main relay click after prime? is that the click you're talking about? if so, and no click, I would suspect the ignition switch (not the key switch), and/or the main relay. main relay is cheap, might as well just toss a new one in there.. ignition switch, I would check pins for if voltage goes to or from it this post should help you with testing that https://honda-tech.com/forums/tech-m...agram-2926002/ |
Re: Thread was move to correct area
There is no click or any sound when trying to start it the dash lights do dim down. Battery is good yes it may be an ignition switch itself. Thank you
I was told there was no relay by parts store.
