power steering lines/AC condenser interference
Old Apr 16, 2019 | 09:31 AM
coelcanth's Avatar
Default power steering lines/AC condenser interference
1992 Civic LX
i am trying to track down a power steering leak. it looks to be coming from either a rusty steering fluid cooler tube or the rubber lines that attach to the cooler tube.
I've removed the front bumper but i'm still having a hard time accessing the lower steering pump lines. is there a way to move the AC condenser out of the way without disconnecting the refrigerant lines ??
any tips or thoughts appreciated
thanks
Old Apr 17, 2019 | 09:52 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: power steering lines/AC condenser interference
Sadly, no. Those are hard aluminium lines. Unbolting the condenser might give you a little play but not much.
Old Apr 17, 2019 | 10:58 AM
coelcanth's Avatar
thanks,
i was able to determine it is definitely the rusty steel cooler tube itself that is leaking,
so by undoing the top hose clamps i was able to snake the whole cooler + two rubber elbow hoses out as one unit.
loosening the condenser did give me enough play to pull everything out through the front valence.
unfortunately the cooler is either discontinued or $130+ from the dealer.
i will either fab something up with copper or stainless tubing,
or take the easy way out and just loop the lower lines with some rubber hose.
any opinions on whether running the PS pump with no cooler is a bad idea ????
Old Apr 17, 2019 | 11:03 AM
deschlong's Avatar
Loved
Community Favorite
My Dad has a 92 Si and has been running without the p/s oil cooler line for 15 years or more.... i.e., like half the life of the car. It's fine. Southern Ontario summers though. May be different if you're in Florida or wherever with a hot climate.
Old Apr 18, 2019 | 12:24 PM
BiggieBert's Avatar
Loved
Community Favorite
Hit up the junk yards, enough 92-95 civics came with power steering, i’m sure a cooler from any coupe/hatch/sedan would work.
Old Apr 20, 2019 | 06:29 AM
tony_2018's Avatar
Fish Twig
They have a hose that loops back. If you want you can use an aftermarket cooler that's similar.
Old Apr 21, 2019 | 12:44 PM
coelcanth's Avatar
thanks guys,
i ended up bending a piece of 3/8" brake or fuel line into shape and using that.. it seems to be doing the trick.
biggest pain was getting the rubber hoses and clamps into position while reaching behind the condenser but i think everything will hold
Old Apr 21, 2019 | 01:11 PM
tony_2018's Avatar
Fish Twig
Originally Posted by coelcanth
thanks guys,
This is where you'll have to find some gas lines that are formed with a 90 degree and cut them for your use, basically custom making your own rubber lines.
THC07
Oct 4, 2006 04:18 PM
90TegraB18C
Aug 15, 2006 05:42 AM
ken2830
Jul 30, 2006 12:40 AM
