2013 accord sport
CVT Capacity: 3.5L (3.7 U.S. quart) at change.
Transmission Fluid Check:
Note: Do not remove the Check bolt before or during refilling of the CVT.
1. Apply the parking brake.
2. Start the engine in P.
3. Move the shift lever through all positions while pressing the brake pedal firmly, and wait at least 3 seconds in each position.
4. Move the shift lever back to P and shut off the car.
5. Remove the Check bolt and sealing washer.
6. The transmission fluid is at proper level if the transmission fluid is dripping from the check hole gradually (a slow and gradual drip).
If the fluid is low, loosely install the check bolt, remove the filler cap and add fluid. Then repeat step #2.
7. With the fluid at proper level, re-install check bolt with new sealing washer.
Pilot King
May 21, 2011 04:31 PM
Clash0901
Nov 4, 2009 05:43 PM
bc_psychocivic
Sep 4, 2003 10:32 PM
