Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
2013 accord sport
Old 04-14-2019, 10:04 AM
mjselling's Avatar
Default 2013 accord sport
I changed the cvt fluid, got about 4 quarts, added the new and only 3 quarts and coming out the level hole, what do I need to do now?
Old 04-14-2019, 12:20 PM
Global Moderator
tech8's Avatar
Default Re: 2013 accord sport
CVT Capacity: 3.5L (3.7 U.S. quart) at change.
Transmission Fluid Check:
Note: Do not remove the Check bolt before or during refilling of the CVT.
1. Apply the parking brake.
2. Start the engine in P.
3. Move the shift lever through all positions while pressing the brake pedal firmly, and wait at least 3 seconds in each position.
4. Move the shift lever back to P and shut off the car.
5. Remove the Check bolt and sealing washer.
6. The transmission fluid is at proper level if the transmission fluid is dripping from the check hole gradually (a slow and gradual drip).
If the fluid is low, loosely install the check bolt, remove the filler cap and add fluid. Then repeat step #2.
7. With the fluid at proper level, re-install check bolt with new sealing washer.
Old 05-14-2019, 02:24 PM
jesser916's Avatar
make sure you don't jack up the car on 1 side. if you jack up the car all 4 wheels have to be on the same level.
Pilot King
05-21-2011 04:31 PM
Clash0901
11-04-2009 05:43 PM
nixadm
14
05-07-2006 09:28 PM
bc_psychocivic
09-04-2003 10:32 PM
GeeSeeR
08-06-2001 04:07 PM
Quick Reply: 2013 accord sport
